new gears
Old Apr 5, 2006 | 08:13 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
new gears
just had 3.42's installed and now getting a howl at 50 and up, is this just the new gears, or are we talking shims, The gears are from Richmond, but they were labeled economy?
Old Apr 5, 2006 | 08:54 AM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
It's common for new gears to make a howling/whining noise.
Old Apr 5, 2006 | 10:29 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Yup, I installed Richmond 3.73's in my 87 TA and they were quit noisy at first but then quieted down a lot after around 150 miles or so. I then switched to a heavier 120-140W gear lube and there is almost no noise now. Only when cruising above 45 mph or so, but when I let off the throttle or just bairly get into it, the hum goes away.
Old Apr 5, 2006 | 02:53 PM
gscz28's Avatar
Car: 89 iroc
I wsa told to run synthitic oil, maybe if I go back to gear lube it will be a little better, I'll let go for awhile and see.
Old Apr 6, 2006 | 11:38 AM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Well, the 320 (120-140W) that I ended up using is a synthetic, but I don't know if it was that or the fact that it is a much heavier lube that helped quiet the gears down.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
