T-56 swap. Bleeding used hydraulics.
Subscribe
Apr 12, 2006 | 04:09 PM
Ok guys, tonight I am going to install the new 4th gen pedals in my 91, cut the hole for the master, etc. I need to know what exactly I need to do to bleed the hydraulics. They are used and complete. The trans is not in the car yet, but I will be installing that soon. I did a search for bleeding the stock LT1 hydraulics and had no luck. If someone could help me out that would be great.
Thanks in advance.
Zach
Reply 0
Apr 13, 2006 | 08:42 AM
Anybody?
Reply 0
Apr 13, 2006 | 08:52 AM
There is no bleeder screw on them I know that. Once I had a problem after doind a clutch on a 97Z. What I had to do was just pump the peddle with the cap off the ressivour. I did that and just kept topping off the fluid. Thats all the bleeding I have ever done.
Reply 0
Apr 13, 2006 | 09:00 AM
Quote: There is no bleeder screw on them I know that. Once I had a problem after doind a clutch on a 97Z. What I had to do was just pump the peddle with the cap off the ressivour. I did that and just kept topping off the fluid. Thats all the bleeding I have ever done.
Grover, how did you manage to pull that off - didn't the fluid go shooting upwards every time you pumped the pedal? - Just curious
-Andrew
Reply 0
Apr 13, 2006 | 12:03 PM
The way I bled my hydralic clutch in my t5 is I got underneath the car, had the resevior filled & Open, and I slowly squeezed the slave cylinder until it was fully compressed (so you don't shoot fluid everywhere) , and then I let it out slowly.. Do that about 3-4 times. & you should have a good pedal.
Reply 0
Apr 13, 2006 | 12:11 PM
Cool, I will try that. Do I disconnect the slave from the bellhousing when i do this? I heard to not pump the clutch pedal while doing this as well.
Zach
Reply 0
Apr 13, 2006 | 12:21 PM
No dont disconect the slave. Fluid will only shoot out if your jaming on the peddle.
Reply 0
Subscribe
