700r4 mods
Old Apr 12, 2006 | 05:36 PM
yaj15
Guest
Posts: n/a
700r4 mods
I've got a '88 iroc with the stock L98 and 700r4. The only mods that I have done so far are a new cat, flowmaster exhaust and hooker headers. I plan to install some AFR 180cc cylinder heads and a tpis zz9 camshaft. I am also going to install some intake runners and a new manifold. Hopefully this should make about 350hp and well over 400ft/lb. Most of the driving that I do is on the street and I ocassionally take the car to the track. What kind of tranny mods should I make? I don't want a rock hard shift like a B&M tranny but I want something that won't slip behind the motor that I've got planned.
Old Apr 12, 2006 | 09:06 PM
toooldforaz's Avatar
Car: 85 z28
Engine: lg4
Transmission: 700r
I did a "shift kit" search before I made my decision on what trany mods I would make and I see that in general people don't like B&M kits and I have also seen many people who have installed the transgo kits tear their hair out because the transmission no longer works properly. So figured less sometimes is more so I installed a corvette servo , a .471 boost valve , a sonnax elavated presure throttle valve spring along with a superior 3-4 W.O.T. upshift throttle valve sleeve. 1-2 shift very positive but not offensive 2-3 is much quicker and overall the transmission feels more hooked up. I have'nt had a chance to try out the W.O.T. upshift sleeve yet , I'll let you know.
Old Apr 12, 2006 | 10:34 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Agreed. Some shift kits are more trouble than they are worth. I would definately step back and look at how much you want to spend on this trans before it is time to tear it down and then do some real upgrading. I would at least go with the boost valve and upgraded trans cooler. Check out Technical Video - Rebuild Your Transmission, Differential, Transfer Case</title>
<META NAME="DESCRIPTION" CONTENT="Rebuild your transmission, differential, and transfer case yourself. Our detailed videos will teach you how!">
<META NAME="KEYWORDS" CONTENT="rebuild, rebuilding, transmissions, differentials, transfer cases, engines, videos, auto repair, automobile videos, mechanic videos">
<META NAME="classification" CONTENT="How-to Videos">
<META NAME="robots" CONTENT="all">
<META NAME="revisit-after" CONTENT="31 days">
<META NAME="distribution" CONTENT="global">
<META NAME="resource-type" CONTENT="document">
<META NAME="window-target" CONTENT="top">
<META NAME="rating" CONTENT="general">
<META NAME="URL" CONTENT="http://www.technicalvideos.com/index.phtml">
<META NAME="author" CONTENT="First Net Impressions">
<META NAME="copyright" CONTENT="Copyright 2003 Technical Video, All Rights Reserved">
<META NAME="title" CONTENT="Technical Video - Detailed how-to videos">
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<SCRIPT LANGUAGE="JavaScript" SRC="scripts.js" TYPE="text/javascript"></SCRIPT>
<LINK REL="stylesheet" TYPE="text/css" SRC="technicalvideo.css" HREF="technicalvideo.css" />
</head>
<body onLoad="copyrightYear();" bgcolor="#B2B1B5" text="#000000" leftmargin="0" topmargin="0" marginwidth="0" marginheight="0">
<table width="741" border="0" cellspacing="0" cellpadding="0">
<tr>
<td width="20">&nbsp;</td>
<td width="720"><img src="images/top.jpg" width="720" height="97" usemap="#Map" border="0" alt="Driveline Plus is a division of Technical Video"></td>
<td width="1" class="black"><spacer type="block" height="1" width="1"></spacer></td>
</tr>
<tr>
<td width="720" class="applet">
<table width="720" border="0" cellspacing="0" cellpadding="0">
<tr align="left" valign="middle">
<td width="130" height="22"><img src="images/todaysspecial.jpg" width="129" height="19"></td>
<td width="590" height="22"><html>
<head>
<title>Untitled Document
. I got my parts and kits from their and they are very heplful. I am not sure if they still sell shift kits though.
i don't know what happened with the reply.
Old Apr 13, 2006 | 08:16 AM
MdFormula350's Avatar
Performance Transmissions–specializing on 700r4 and 4L60e
- Street/Strip Premier 700R4 Update
- 700R4 Rebuild Kit-Street/Strip
Very pleased with his rebuilt kit my brother put in for me. I cant believe i have a 700r4 that shifts
Old Apr 13, 2006 | 11:51 AM
Shagwell's Avatar
Car: projects.......
...Superior shift kit, billet servos. Thats about the best you can do before taking it out and upgrading the internals. Plus, even if down the road you do take it out and upgrade these will still be parts that you want on it.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
