Torque Converter is making noises
Old Apr 14, 2006 | 07:53 AM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
Last fall I had a brand new transmission put in (4L60E), and ever since it has made a ticking/tinging noise. Until now it sounded like the exhaust was banging on the floor, but it has plenty of room. Now it changed pitches of noise to a higher pitched ting/ping. I lifted the car up and checked out the converter. It is tight to the flexplate, and everything is tightened down. While runningm, though, you can hear a tinging noise that climbs with the RPMs, and it sounds like it is coming from the inside of the TC. I tapped on the TC with some metal on the outside housing and it makes the same noise as it does while running. Does anyone know what happened to my TC, and if I will need a new one???
Z28crossfire
Old Apr 14, 2006 | 12:26 PM
Shagwell's Avatar
Car: projects.......
...sounds to me like the stator is rubbing the fins. - maybe just losse and shifting around, but still, yes, new converter.
Old Apr 14, 2006 | 01:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah anytime you get a new trans, you should look into a new convertor and not reuse a stock unit.
Old Apr 14, 2006 | 01:31 PM
Car: '94 Z28
Engine: LT1 350
Thanks guys, that's what I thought. Do you recommend getting it replaced ASAP, or should it be safe for a while? I've already put 3k miles on it with this noise.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
gwade12
Aug 8, 2015 08:17 AM
