hydraulic to mechanical linkage
Old Apr 15, 2006 | 09:37 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i have a retro fit t56 in my car that uses the stock hydraulic set up. i hate the way the pedal feels. i wanted to know if i could swap it to a mechanical set-up. i have a mcloud clutch in the car now and the pedel is too too soft. the car shifts fine and its a brand new clutch in it. i also have blown the slave clyinder twice on the car. i was wondering if it has anything to do with heat distorting the plastic.
Old Apr 16, 2006 | 08:13 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Could be the heat. Also using the wrong type of brake fluid can cause it too. Using synthetic or silicone fluid can cause the seals to soften & blow out. Use standard DOT 3 only. Mechanical linkages have there headaches too. Bending, cracking, binding & breaking are all common problems with mechanical linkage.
Old Apr 16, 2006 | 12:56 PM
smokefan's Avatar
i know its not the fluid cause i used a dot 3 fluid. maybe heat though
Old Apr 16, 2006 | 01:23 PM
Brettlinetta's Avatar
Car: 85' Berlinetta
Engine: Twin Turbo 350 coming soon
Transmission: TH350
Axle/Gears: 10 bolt 3.42 posi
Have you completely bled the circuit? The number one cause of failure in hydraulic clutches is dirty fluid, a good way to fix this is to use a pressure bleeder, and pump a metered amount of fluid through the circuit until you are sure that it has been completely flushed.
residual dirt in the lines could cause all the problems you described, especially blowing all those slave cylinders. Just my
_bR3T7
Old Apr 16, 2006 | 03:36 PM
smokefan's Avatar
i know its not dirt or any other debris since i installed the cyliner and added fluid from a new sealed can of dot3. maybe i am not bleeding it the right way since my pedal is so soft.
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
