throw out bearing replacement
Old Apr 16, 2006 | 04:12 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
How do you get it on there? The fork won't slide back to get it around the collar? It looks like the fork pivots on something, but I can't get to it...?
any ideas?
Old Apr 19, 2006 | 11:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
nobody ? I've been searching for a while now, and i'm now going to make sure to clip the fork ears into the groove of the TO bearing correctly, however, how do I get the fork to slide outwards?
Motor is out of the car, tranny is sitting in place with fork not connected to pedal right now. I can remove the grommet around the fork, and get the fork to slip on it's pivot point inwards and outwards a little bit, but not enough out to get the TO bearing in.... What's the secret??
Old Apr 20, 2006 | 06:07 AM
The fork has a sort of 2-fingered clip that holds it on the pivot ball. It's fastened with a rivet, between the ball and the throwout bearing end. The clip thing will prevent it from sliding outwards. To get it off the ball, it has to slide toward the throwout... inwards. But if the trans is still attached to the BH, it can't.
The trans and BH must be separated.
Old Apr 20, 2006 | 11:29 AM
Sonix's Avatar
Car: 1982 Trans-Am
oooohhhh ok. That explains why no one else seemed to have this problem, everyone else had the motor in, and just removed the trans. So can I leave the tranny connected to the TA, and shifter in place in the car, and just remove the bellhousing via the 4 giant torx bolts or whatever they are?
thanks
Old Apr 20, 2006 | 12:36 PM
Yup, absolutely.
The 4 bolts are Torx, and also 15mm.
You'll see exactly what the deal is when you get there.
Old Apr 24, 2006 | 02:20 PM
Sonix's Avatar
Car: 1982 Trans-Am
got 'er done, actually, torx and 19mm. Now I understand what they meant by "install the bearing to the fork".... Easy as pie.
Thanks again sofa
anesthes
Mar 10, 2016 10:35 PM
red90IROCls1
Aug 25, 2015 06:56 AM
justin57
Aug 20, 2015 07:05 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
rsrmoore
Aug 7, 2015 08:44 PM
