auto tranny fluid change problem
Old Apr 16, 2006 | 09:07 PM
purg3d's Avatar
Car: '92 RS
I just changed the transmission fluid and i've been trying to get the fluid filled right. its reading at cold when its warmed up and when i cut it off its been reading above hot. before i changed the fluid it was overfilled and im thinking maybe the vent is clogged and the torque converter has air in it or something? i need input please also the transmission core in the radiator had popped earlier in the week and the tranny was almost bone dry
Old Apr 16, 2006 | 10:35 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
When you do a pan gasket and filter change it should take about four qts,and check with car running in park and let it warm up.
Old Apr 16, 2006 | 10:43 PM
purg3d's Avatar
Car: '92 RS
thanks for the post... i put a 15 oz additive (k&m trans-x) in the tranny and about 3 5/8's quarts of transmission fluid in it. i checked it while running in park after i drove it around and after it warmed up before i drove it and a cupple times after it cooled and it still read at cold and i had to fill it up that high risking overfilling it... could the torque converter be going bad?
Old Apr 17, 2006 | 05:24 PM
purg3d's Avatar
Car: '92 RS
found out today its supposed to dump the transmission fluid back into the pan after you cut your engine and the level read while its in nutral or park is the right reading... just needed more fluid than 5.9 pints
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Leggman1
Aug 6, 2015 04:15 AM
