Torque Converter?
Old Apr 16, 2006 | 11:02 PM
Bane's Avatar
Torque Converter?
I'm new to these boards, but they look like a friendly place, so i thought i would start off with a question. I'm driving a 1986 T/A with the stock 305 carb's engine. I have a th700r4 transmission, and in the near future plan on uping the engine to a 350. Now i was wondering what the best torque converter for the mildly modded 305/350? How difficult are they to install? Are they worth the money? Any help would be great, I'd really appreciate any input on the different brands.
Old Apr 16, 2006 | 11:25 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
we need more info on the motor for a good recomendation...specs on cam, heads, intake, etc.
Old Apr 17, 2006 | 12:07 AM
Bane's Avatar
Its literally a stock 305. The only thing that i have changed on the car is the exhaust system and just minor upgrades like spark plugs and cap and rotor. The timing chain is being set this week with a new thrust bushing in and a new harmonic balancer is going on, but nothing fancy. What im looking to do is get something that i can install on the 305 and work now, but also install on the 350 when i get one.
Old Apr 17, 2006 | 07:35 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If you are simply looking for something with good seat of the pants, and not very converned with 1/4 mile et, something in the 2000-2200 range will work now and give you room to grow. If you are looking for the"perfect" converter. Wait unit your combo is finalized. At least on paper.
Old Apr 17, 2006 | 02:33 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
"You get what you pay for" is especially true with torque converters. Just something to keep in mind. If it were me, I would give Andre at Edge Racing Converters a call. He's arguably the best converter guy there is.
Old Apr 18, 2006 | 01:52 AM
midnightcamaro's Avatar
very true when i finished my car for the 1st time i went with a dayco converter well after about a month it took a **** and and ruined the transmission that had just been built. and dayco wouldnt do anything about it and wanted me to buy another one. i got a TCI and was very pleased it stalled higher than the dayco did and was rated at a less stall than the dayco. i was in a rush to finish it and dayco place is nearby yea i wont be doin that again. but Bane it wont be of much concern yet but if u start gettin a lot of stall u should deff. put a trans temp gauge in the pan to monitor temp thats the worst thing for an automatic. also better cooling pan and good trans cooler.
Old Apr 18, 2006 | 08:27 PM
92camaro's Avatar
Listen to Midnightcamaro, don't buy a cheap convertor. Buy a good convertor like TCI, Coan, Edge something good. But don't waste your money on the 305. Build your 350 and then fine a convertor to match the engine.
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
