10 bolt LSD rebuild, how hard is it?
Old Apr 17, 2006 | 11:09 PM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
Axle/Gears: limited slip disc
I have an 83 disc LSD 10 bolt rear that slips more than it limits. I was wondering how hard it is to rebuild and what tools I will need.
Thanks,
Will
Old Apr 18, 2006 | 02:33 AM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
rebuilding the unit is not that difficult. The hard part is finding the replacement parts. I think it would be better to get a new posi unit. They are stronger and usually more precise. The only special tools you will need are a torque wrench, a dial indicator with magnetic base, and an in/lb torque wrench. You can actually do without the in/lb wrench and just "feel" the resistance on the pinion gear. I would also suggest you get to know somebody with a press. You will need this to get the bearings on and off.
Old Apr 18, 2006 | 06:11 AM
That unit is either an Eaton Gov-Lock or it's an Auburn.
If it's a Gov-Lock, it will have some funky little weights visible in the "window" of the carrier; if it's an Auburn, it will just have some springs.
If it's a Gov-Lock, it needs to go STRAIGHT TO THE TRASH.
If it's an Auburn, the parts are non-existent.
If they existed, it wouldn't be too hard.
I have a 97 model Auburn, i.e. 14 years newer than yours, that needs service; I called Auburn themselves; they don't even supply parts for one that new.
Time for a new unit.
Old Apr 18, 2006 | 11:19 AM
priest1981's Avatar
Car: 86 IROC-Z
Engine: LB9
According to your description I think it is a Gov-Lock, it has some little round thing that is hanging of the side of the window to the side gears.
Thanks,
Will
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
hectre13
Aug 26, 2015 08:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
