9 bolt axle will not come out
Old Apr 21, 2006 | 08:21 PM
net_coma's Avatar
I am replacing the 9-bolt with a 10-bolt and the drivers side axle on the 9-bolt will not come out. I removed the passengers side a few months ago with little effort. I used the pull and plead method followed buy the BFH and invented words and it will not move. If bent a tad will it be hard to remove and how do I entice it out? I need the backing plates off.
Suggestions? I have no armour piercing rounds.
Old Apr 22, 2006 | 04:18 AM
irocman7's Avatar
Car: 89' Sunset Metallic Orange Iroc-Z
Engine: Forged 383
Transmission: TR6060
Axle/Gears: 4.11 9 inch
I had the same problem with my passenger side, it was stuck. I eventually took the sledge to it and that didn't get it. What finnally got it was using a car jack, like the original and using it like a press with a plate between the backing plate and the hub. It pressed out fairly easily, you could probably use a hydralic press but I used what I had.
Old Apr 22, 2006 | 05:10 AM
ede's Avatar
ede
try a slide hammer
Old Apr 22, 2006 | 03:12 PM
net_coma's Avatar
Thanks for the ideas. I don't think the slide hammer I have is big enough but I do have a jack and will try that later when released from household chores.
Old Apr 24, 2006 | 07:21 AM
net_coma's Avatar
Jack did the trick. Turned the rotor backwards, put a pad between jack and rotor and probable less than one turn on the jack screw and it was out. Probable bent as it does not want to go back in place. (headed for scrap so no problem there.)
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
dbrochard
Oct 3, 2015 12:43 PM
Jlanz55
Sep 6, 2015 07:28 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
