starts in second?
Old Apr 22, 2006 | 01:00 AM
iroc86z's Avatar
Car: 82 Z
Engine: 350 carb'd
Transmission: th-350
Axle/Gears: 3.08 posi
starts in second?
i just replaced the governor gear on my 700r4 becuase it wasnt shifting at all. this fixed the shifting problem ,but i think it has been starting in second for awhile, even before the governor went. it stutters alot at low rpms, and i can downshift it manually into first, but i believe it is starting in second. any ideas on what could cause this?
thanks
Old Apr 23, 2006 | 09:52 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Your transmission cable is set wrong? I'm not sure. If you can manually shift it into first, and first works fine, then I'd look at the cable play first, before ripping into the transmission.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
