Normal to be able to wiggle 700R4 output shaft with your hand w/ driveshaft removed?
Old Apr 26, 2006 | 10:45 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I have never worked with 700R4s before now. I noticed when I was installing my used, supposedly good 700R4, that I could grab the output shaft and wiggle it around with my hand. Is this normal? I wasn't sure if the trans yoke bearing against the output bearing supported the shaft, so the shaft floats, or if it should be rigid and there is a problem with my trans. I just drove the car around a big parking lot today and it goes into drive and reverse and seems to drive okay, but I want to make sure before I take this thing any distance if I have a time bomb on my hands or not.
Old Apr 26, 2006 | 11:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Depends how much it moves. The shaft rides on a bushing. It can't be tight or it will seize up but it can't be real loose or the rear seal will start to leak.
Old Apr 26, 2006 | 11:58 PM
Car: 2000 BMW M5
How much is normal wiggle? It was enough wiggle that when I was expecting the shaft not to deflect at all it scared the hell out of me. I'm guessing it was around 1/8" side to side wiggle? This wasn't the amount of play I would expect from something riding on a bushing. Is the bushing up front and the rear of the shaft is unsupported except for the driveshaft riding in the rear bushing holding it up?
Old Apr 27, 2006 | 07:21 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
1/8 is the amount of wiggle. The clearance is much tighter. Sounds like it is good. The case bushing is the one wiggling. It supports the output shaft. The bushing in the tail housing supports the driveshaft yoke.
gta892000
Aug 11, 2019 11:16 AM
loud91rs
Oct 5, 2015 10:05 PM
HikoriYami
Sep 21, 2015 07:11 PM
Stroopwafel
Sep 11, 2015 06:38 AM
