Wanting to swap to lower gears Ex- 3.23 to 3.42 or 3.73's- how do they affect perf.?
Old Apr 27, 2006 | 11:55 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Engine: Rebuilt Vortec Headded 358SB 9.5:1
Transmission: 700r4, corvette servo, Transgo kit
Axle/Gears: 3.23 POSI
Ok- i have my 86- and it currently has a set of 3.23 gears in its stock rear..
I want to go with some lower gears, but still get decent gas mileage.. The lowest i want to go is to 3.73's..
What i need to know-
what series carrier do i have in my rear?
What differential do i have in my rear?
How does changing from say 3.23's to 3.42 or 3.73's affect the cars performance and off the line tourque?
how hard is it to swap out a ring and pinion assembly and what all will i need to get when i do the swap?
All answers are greatly appriciated. THANKS!!!!
Old Apr 28, 2006 | 03:30 AM
ede's Avatar
ede
if you have a factory carrier it's a 3 series. it should be a 10 bolt from the factory, again you should get under the car and take a look. what GM did and what you have may not be the same thing. in a nut shell lower the gear the more you'll feel it pull and the less milage you have. you'd need some sort of special tool to hold the yoke, in/lb dial type torque wrench, mag base and indicator, depth mic or pinion setting gage, ft/lb torque wrench, press, bearing seperator, 0-1 mic or caliper is good to have. you'll need at a minimum the gear set new pinion nut and clush sleeve/spacer. if the bearings are questionable you'd want new bearings too. an assortment of shims is always good to have. you can buy install kits with all the hardwear you'll need. i'm suprised you didn't find all this info when you did your search. i'm thinking me and a couple of others have posted it before.
Old Apr 28, 2006 | 01:06 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I went from a 2.73 to a 3.73 and the difference was night and day. It was an awesome upgrade and well worth the money and mileage (which wasn't much) I went from around 20 to 17 on the freeway and my in town mileage did not change much if at all.
However, with the stock LG4 dropping off sharply after 4500rpm it was too steep of a gear for the LG4 if left in stock trim. But for the mildly built 355 I installed they will be perfect.
Off the line torque was greatly improved. The LG4 couldn't do a burn out with the peg-leg open rear to save its own hide. But once the posi and 3.73's were installed, I could roast the tires through first and almost all the way through second.
Old Apr 28, 2006 | 03:53 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Well a buddy of mine has 4.10's, and he gets really ****ty mileage, so the lowest i want to go would be to the 3.73's.. And my 358 has a hell of a top end with the vortec heads on it and pulls strong deep into the 5 grand mark..
I think i'll say screw the 3.42's and go with the 3.73's..
Thanks both of you!!!
Old Apr 28, 2006 | 04:03 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Another question- How do i know if i have a 7.5 or 8.5 rear end? And- how far will switching to 3.73's throw off my Spedometer, and how can i correct it?
Thanks again!!!
Old Apr 28, 2006 | 04:07 PM
It's real simple to tell: do you have a 82-92 F-body 10-bolt? then it's a 7.5". There are no 8.5" in these cars.
Old Apr 28, 2006 | 04:26 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Ok- that works, cleared that one up quick.. THANKS!
Old Apr 28, 2006 | 06:25 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
you can get a different speedo gear or do what i do... go with traffic... i never had a speedo so i got used to it
Old Apr 29, 2006 | 08:29 AM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I think it would be a good choice since, in my opinion, don't see much of a difference going from a 3.23 to a 3.42 for the cost that will be incurred.
In fact, your 3.23's with the right TC might be just fine with the 358 if you are only pulling to 5-5.5K or so. But if I have to choose between fine or fun... Fun always wins.
Old Apr 29, 2006 | 08:43 AM
indirocz28's Avatar
Car: 1986 IROC Z-28
Yeah, someone said that i could put a 3800 stall in my 700 and still get about the same gas mileage probably as you do w/ the 3.23's...
but - im still thinking of the 3.73's..
Old Apr 29, 2006 | 12:33 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
well whats more fun... 20 mpg and 50 ft burnouts or 15 mpg and being able to light the tires for 200ft
Old Apr 29, 2006 | 01:20 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
Exactaly- but i also wanna be able to hook up on the track..
Old Apr 29, 2006 | 02:00 PM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
If your speedo and odometer don't work, then you won't need to worry about the speedo gear. If your speedo & odo work, your speed will be reading faster and your mileage will click quicker. If you don't care about the number of miles on your car (I hope I don't cry when my car hits 100,000), then there's no big deal, either. But if you care about your speedo being acurate: your speedo will be off in percent. Your trans will be spinning more times to turn the wheels, thus, speed will read more. If your doing 70, and your speedo is reading 77, your off 10%. You would need 10% more teeth to slow the speed down. Your gear is 20 teeth. 10% of 20 = 2. You would need 22 teeth. If that helps any.
Old Apr 29, 2006 | 02:57 PM
indirocz28's Avatar
Car: 1986 IROC Z-28
well- they work, but, does anyone make a changeover kit?
ZZ3Astro
Aug 13, 2019 12:57 AM
mfp189
Sep 27, 2015 09:25 AM
305IrocZ28
Nov 14, 2001 07:16 PM
Sharky
Aftermarket Product Review
Jun 19, 2001 06:33 PM
84IROC
Oct 5, 2000 09:42 PM
