Th-350C Lockup...
Old May 2, 2006 | 10:07 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Th-350C Lockup...
Does anyone out there know if the 700R4 lockup plug will work on the Th-350C and if the wire is on the right pin or do i have to move it?!?!
Old May 2, 2006 | 10:41 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
well i found this in a different forum...
so here's how it works. There are three wires on the connector at the transmission. Purple is 12V+, brown is ground, and green is the 3rd/4th gear signal to the ECM. The purple wire is routed through the brake light switch to supply 12V+ from the gauge fuse to the lock-up solenoid any time the brake pedal is all the way up. The brown wire is goes to the ECM, and it grounds the solenoid whenever the correct conditions are met for lock-up. On pre-ECM cars, the brown wire went to a ported vacuum switch which locked the converter when you were driving with above 10in-hg manifold vacuum. They also used a pressure switch in the transmission which only allowed lock-up in high gear.
Anywho, with no ECM, the green wire is meaningless to you. Leave the purple wire as-is. Install a toggle switch between the brown wire and ground to lock up the converter. It's also a good idea to make sure you have a 3rd gear pressure switch so that the converter will only lock-up in third and so it unlocks if you accidentally kick it down into second gear and forget to flip the switch
So i guess i will have to hack up the old 700R4 plug. Now i need to know which pins were originally the brown/purple/green...
Old May 2, 2006 | 01:28 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Anyone...?
I kind of think the guy in the other forums was full of BS, i only remember their being 1 wire when i had the pan off...
Old May 2, 2006 | 07:26 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
ok well after googling for hours on end i found another site that states their is only 2 of the 4pins on the connector for the lockup.
The forwardmost pin is +12v and the rearward pin is ground...
Fast355
Carburetors
Dec 16, 2013 03:40 AM
Silver_Panther
Sep 6, 2005 07:36 AM
matt_82transam
Mar 1, 2004 02:21 PM
