700r4 from 90 Iroc into 86 iroc?
Old May 3, 2006 | 07:05 PM
IroczInOz's Avatar
I just need to know if there are any problems I need to look out for in such a swap. A friend of mine is going to install a T56 into his Iroc and is selling the 700r4 out of his 90 iroc. I have a 86 iroc and thought it might be a good opportunity to swap out my transmission.
Are there any issues with such a swap? What would I have to change? Is the rear main seal compatible, would I have issues with the VSS?
I am running MAP and A 730 ECM in my 86 camaro now. Would I just enable optical VSS instead of magnetic (or something along those lines)??
Any advice much appreciated.
Old May 4, 2006 | 06:22 AM
It's not really a swap. They are the same, externally.
Just take all the speedo stuff out of yours and put it in the other. Piece of cake.
Old May 4, 2006 | 09:39 PM
IroczInOz's Avatar
So basically the electonic pieces that mount onto the transmission take them from my 86 and mount them onto the 90 and I should be sweet.
What is your opinon is it a worth while swap. Is the 90 model trans better? I have a feeling my 86 might be slipping or not changing correctly even though I have done everything I can with it.
Old May 5, 2006 | 06:45 AM
With the 700, a later model is usually more desirable, because they were constantly upgrading things during its prodcution life.
If your current transmission slips, then it's not long for the world; and you're gonna have to do something soon. So replacing it with the other might be as good an option as any.
Old May 6, 2006 | 11:25 PM
IroczInOz's Avatar
Before I go ahead and do it. Is the output shaft spline the same too?
I just don't want to find out I have some problems later on.
Old May 7, 2006 | 11:57 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
the output shaft splines are the same on all 700's.
BlueIroc-Z
Jun 9, 2019 03:22 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Leggman1
Aug 6, 2015 04:15 AM
