Solid Spacer/sleeve question
Old May 5, 2006 | 04:10 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
In the near future, I'm ordering a Ring & Pinion, Master Overhaul Kit, and a Positraction Carrier for my camaro. In my last post, someone mentioned about getting a solid spacer...the guy from Randy's Ring & Pinion and my Transmission guy never mentioned anything about a spacer or a Cruch Sleeve....what does this mean?...is there something I need to tell this guys when i order my gears? (My car has the original 10 Bolt 7.625" Ring Gear 26 spline shaft)
Old May 5, 2006 | 05:32 PM
ede's Avatar
ede
just order a solid spacer. i think a crush sleeve might be in the over haul kit.
Old May 5, 2006 | 09:07 PM
Car: 1988 SC Camaro
Engine: 305 TBI
what is the purpose of a spacer?...is there a stock spacer?
Old May 5, 2006 | 10:20 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
the solid pinion spacer prevents the pinion from walking up the ring gear...
i plan to buy one for my rear end overhaul one of these days as well.
I would also look into upgrading to 28 spline axles, for the added peace of mind. moser axles sell for around 235 bones on summit. if you go this route, make sure your posi accepts 28 spline axles.
hope this helped!
brandon
redmaroz
Apr 25, 2017 07:14 AM
Mutillator
Sep 17, 2015 04:38 PM
87iroctheo
Wheels and Tires
Sep 2, 2015 03:29 AM
Bert87
Aug 23, 2015 03:50 PM
redmaroz
Aug 16, 2015 11:40 PM
