engine and tranny removal "for dummies"
Old May 9, 2006 | 01:08 AM
joshnryandad1's Avatar
Car: 1991 camaro rs
Engine: 3.1
ok, i have never pulled a tranny(700r4) from a third so don't laugh! ok i'm pulling the motr and tranny out of my 91rs to transplant a v8 from another 91rs. i have the motor ready i just need to know what i will nee to remove(bolts, wires , sensor plugs....) to pull both the engine and tranny!! oh! its a 91rs with a 3.1l with a 700 getting a 305tbi with another 700. any help that you can give will be great! yes i have searched and didn't come up with what i need.
Old May 9, 2006 | 01:33 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Easy.
Disconnect battery
Drain all the fluids first.
Disconnect all wiring.
Disconnect shift linkage and drive shaft.
I usually pull the A/c and power sterring off and hang them to the sides of the engine out of the way.
Remove engine mount bolts.
Remove trans crossmember and support with jack and a board.
Pull it out
later
Jeremy
Old May 9, 2006 | 02:15 AM
Car: 1991 camaro rs
Engine: 3.1
ok so it is very similar to taking a t350 out!
Old May 9, 2006 | 08:01 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
don't forget swapping from v6 to v8 involves moving the motor mounts on the kmember as well. while you're there swap to poly motor mounts since they'll be out anyways. most of all good luck on your project. if you have questions we'll be more than happy to help you along the way.
Old May 9, 2006 | 09:52 PM
Car: 1991 camaro rs
Engine: 3.1
thanks fellers!! i'll have the help of my dad and 2 brothers but if i need any help at all i will definitely call on you guys!!
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
