3.73s
Old May 9, 2006 | 06:31 PM
TundPortZ's Avatar
3.73s
quick question, my car is an 86 IROC 305 TPI, 3.23, auto, would 3.73s be too much for it? ive got a mild cam, full exhaust, all free mods. Thanks
Old May 9, 2006 | 06:47 PM
iroctj's Avatar
Car: 86 IROC-Z
Engine: 385 TPI
Transmission: 700-R4
Axle/Gears: 9Bolt 345'S
gears
these will help but it will increase your rpm in top gear & lower your top speed. Not to mention less mph per gallon--rock on!
Old May 9, 2006 | 10:05 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I had the same drivetrain combo when I was an auto and it made a huge difference in performance, car launched harder and faster, went .5 seconds faster in teh 1/4 and gained 3mph.
you should still be able to hit 140mph in 4th. mpg may suffer slightly, but when you build a fast car, mpg shouldn't be too much a concern, if it is then you should get an econonbox beater.
Old May 9, 2006 | 10:30 PM
net_coma's Avatar
Throw a t56 in front of the 3.73 and with the .5 overdrive in 6th you will wonder why not a 3.90.
Old May 9, 2006 | 11:11 PM
Zepher's Avatar
T56 and 4.10's, that's the combo.
Old May 9, 2006 | 11:13 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Typically a TPI setup will not make any power in high RPMs so you would want to keep a high gear (numerically lower) as to not keep the motor out of its powerband.
But it all depends if you want to try to do 500mph top speed...
Old May 11, 2006 | 07:25 AM
TundPortZ's Avatar
Well im not really concerned with going 150 mph, i just want something thats not gonna run outta steam in the 1/4. More than anything, i just wanted to know if it would make it noticeably faster stoplight to stoplight.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
JSDaddy189
Sep 26, 2015 03:50 PM
whyt86roc
Sep 10, 2015 10:03 PM
