URGENT: 3rd Gen disc axle with no posi? Can I fit my posi?
Old May 11, 2006 | 09:35 AM
HardRockCamaro's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Transmission: TH700R4
Axle/Gears: 2.73:1 Posi
Right, I have a chance to get a 3rd gen rear axle 3.23:1 that has discs.
I have drums on mine and 2.72:1 so it would be a great swap.
However I have a posi and the axle with discs does not.
My car is an 88 5.0TPI IROC with the posi rear end and drums (from the factory).
The axle for sale is apparentley off an 86 Camaro (that's all the seller knows about it).
Will it all just work together so I end up with a posi and 3.23:1 and discs?
Old May 11, 2006 | 10:05 AM
No unfortunately it won't.
Your 2.73 is a 2 series carrier, and the 3.23 is a 3 series. The ring gear will miss the pinion by about .300" .
You need a ring gear spacer. Then it will work.
You'll hate the 86 disk brakes. That's arguably among the worst brake systems GM ever put on their cars. They also won't work very well with the drum master cyl and proportioning valve; those calipers (cast-iron Saginaw) require those other parts to match them.
Old May 11, 2006 | 10:11 AM
Well that ideas out of the window then...
Livingt in the UK is a PITA.
I want discs on the back and these cars are pretty rare over here so I can't just go looking in a scrap yard for an axle as there won't be a 3rd gen in there...
Back to the drawing board I guess!
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
