Will this T-56 swap work?
Old May 15, 2006 | 02:39 PM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Hi all,
I need to bow to the transmission gods on TGO for a few minutes here. I have a couple of quick questions.
I have an opportunity to buy a T-56 six speed manual tranny out of a 2002 Z28 for $1500. The tranny has about 30k miles on it, and was driven before the car was parted out. The seller says that it worked when he drove it, and I trust that he's being honest with me.
1) Is $1500 too much for this setup? I already have the pedal box from the car, so I would be getting the tranny, cylinders and lines for that price.
2) Will there be any problem retrofitting a 2002 T-56 to a small block chevy? Right now I have the L03 305ci motor in my 1992, but I will be upgrading to a carbed 383 very soon. I just need to know if the swap is do-able or not...
Thanks guys, any help is GREATLY appreciated!
Old May 15, 2006 | 03:01 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i think the bellhousings on the ls1 wont fit, and the input shaft is different.
Old May 15, 2006 | 07:41 PM
Engine: 5.0L TPI
Axle/Gears: 3.08
Interesting, so a 98-02 t56 cannot be adapted to a small block?
Old May 15, 2006 | 08:37 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
They can be I believe mcleod makes a bellhousing for the conversion but dont quote me on that
Old May 15, 2006 | 09:00 PM
Engine: 5.0L TPI
Axle/Gears: 3.08
Are there any pros out there with thoughts on this $1500 opportunity?
Old May 15, 2006 | 09:01 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You are right, they do infact make one.
Old May 15, 2006 | 09:06 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
$1500 is to much for a trans that won't fit without more parts. you can get an LT1 T56 for that price easy enough, and it's a near direct bolt in.
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
cRoe4
Aug 7, 2015 08:46 PM
