2.73 (10 bolt? to 3.27 (9 bolt) speedo gear
Old May 16, 2006 | 02:12 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
What color/tooth number do I need for the 3.27 9 bolt for my cable driven speedo?
Kevin
Old May 16, 2006 | 02:56 AM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
You might get your answer faster just by calling any local Trans shop.
Here is the number for Hipster up here, I know they would know. (262)251-7777
Their parts are offered in Jegs, so I know they know what they are talking about.
Old May 16, 2006 | 01:20 PM
Engine: L98 350 TPI
I was hoping someone here has swaped in a 3.27 9 bolt so i can just order the speedo parts and get on my way.
Thanks Knyghtmare for the phone number, I will probly end up calling them if no one else knows.
Kevin
Old May 16, 2006 | 09:22 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
good info here
700R4, 700R4 Speedometer Gears, 4L60, 700R4 Speedometer Calibrations, 700R4 !
Old May 17, 2006 | 01:25 AM
Engine: L98 350 TPI
Bu the closest thing they have is for a 3.23 gear.
Kevin
Old May 17, 2006 | 01:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Close enough. Your speedometer isn't that accurate anyway.
Old May 17, 2006 | 03:05 PM
Engine: L98 350 TPI
What did the factory 3.27 9 bolt cars use for their trannys?
Kevin
hectre13
Dec 11, 2023 08:14 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Regal105
Aug 23, 2015 03:45 PM
knight72
Aug 10, 2015 09:32 PM
