4th gen rear conversion complete
Old May 16, 2006 | 03:44 PM
Ant's Avatar
Ant
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
Just got my rear out of a 94 z28 in. The only problem I had was that the bolts that bolt the caliper to the axle assembly were to short and i had to buy longer ones other than that everything went well. Also if anyone is interested in this swap take into accont that your wheel really do stick out 2 more inches so if you lower your car it may rub the tires when you hit a bump on the free way.
Old May 16, 2006 | 09:32 PM
Reddragonboy's Avatar
Car: 1989 Firebird
Engine: 305 tbi
Transmission: Borg Warner T-5 spd
suspension pieces
what control arms and panhard rod did you use. were they for 3rd gen or 4th gen?
Old May 17, 2006 | 08:44 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
They're all the same . Not really much of a conversion as it all bolts right in.
And don't do the swap and use the stock thirdgen wheels, it just feeds the mu11et stereotype.
Old May 17, 2006 | 11:45 AM
Shagwell's Avatar
Car: projects.......
- well, it's not too bad if you're running the 16" Iroc or GTA wheels. Then they atleast stay under the car.
Old May 17, 2006 | 04:30 PM
Ant's Avatar
Ant
Yeah it was pretty much a direct bolt on, pretty easy next is the five speed swap since I just upgraded from 2.77 gears to 3.23's.Now I am looking for a set of fourth gen zr1 wheels since my back tires stick out so far. I will post some picks this weekend.
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
