Cracked Flex plate
Old May 17, 2006 | 04:38 PM
Mcotto's Avatar
Cracked Flex plate
Whats up guys, this is my first post here, I have a 92 firebird convertible that I recently bought it had a cracked Flex plate, and I replaced it and not even 10k miles and its cracked again, and my front pump seal is leaking any body have any suggestions as to what could be the problem? I apreciate any help. I was told my converter could be out of balance.
Old May 18, 2006 | 06:03 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Are you sure that you got the tranny bolted to the engine with a tight fit everywhere. If they don't get perfectly aligned the flex plate will have to take that movement with every engine revolution.
Old May 18, 2006 | 11:27 AM
Mcotto's Avatar
Im sure the its tight, but Im gona pull the trans this weekend so I will find out. Thanks for the tip.
Old May 19, 2006 | 12:18 AM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
you need to make sure that its tight to the engine case a frind of mine had some (all) of his bellhousing bolts start to walk out on him in his truck and the damned thing ripped the entire center of the flexplate off from the outside
Old May 19, 2006 | 09:02 AM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
What did your cracked flexplate sound like? My car is making a tinging/pinging rattling noise when accelerating, and I'm hoping it isn't the flexplate.
Old May 22, 2006 | 09:51 AM
Mcotto's Avatar
It
it goes away, or is not as bad under acceleration or in gear unless its really bad, on my car its alot more noticable at idle, it sounds like detonation or pre ignition whats going on with your car, you should check your EGR valve and timming.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
tyeo098
Nov 30, 2015 06:27 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
codeysabatini
Nov 10, 2015 04:07 PM
