cluster gear change
Old May 20, 2006 | 12:22 PM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
cluster gear change
I am working on rebuilding my T5 WC. The cluster gear that is in it has 053 stamped on it, and I was wondering if I can use a cluster gear that has 070 stamped on it. I was on Hanlon's web site and they do not have a 053 shaft but the 070 has the same gears on it. From what I can see they seem to be an upgraded higher alloy version for the Ford Mustang.
Old May 20, 2006 | 03:28 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i'm pretty sure you can't. gear diameters and tooth angles are different.
Old May 26, 2006 | 11:32 PM
Souseless's Avatar
Car: 89 WS6
I asked Hanlonmotorsports and they said that it works perfectly in case anyone else was interested.
Jeremys87
Jul 14, 2022 09:08 PM
jbd1969
Aug 17, 2015 07:06 PM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
