Advice on speedo drive gear
Old May 24, 2006 | 03:34 PM
FoxRodder's Avatar
Car: Fox Body+Third Gen Cam
Engine: a few
Transmission: few more
Ok so I already did a bunch of searching but was wondering if I could get some extra help. Since I got my car it had no function from the speedo. I figured it was a bad cable. I pulled the driven gear/cable out of the tailshaft to try and spin it and see if speedo would move and it did. I found that the drive gear was completely free spinning on the shaft and the clip fell out.
So if I pull off the tailshaft housing, I can remove the gear from the shaft? How exactly would that work? I'm thinking I'd want a new gear while I'm at it because I dont know if its possible that the gear is too loose.
Old May 25, 2006 | 06:06 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Changing speedo gears (4L60/700-R4)
I did it cause I went from 2.73s to 3.42s, easy as pie dude!
Here is a tech article on it.
Old May 26, 2006 | 08:03 AM
FoxRodder's Avatar
Engine: a few
Yea I found that with some searches. Pretty helpful. I'm trying to make sure I get the parts beforehand. My gear looks fine but I dont know why it came off in the firstplace other than when the tranny was swapped or rebuilt. I dont know how they could put it back on wrong. I want to grab a new clip and seals just in case while I'm in there.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
beachrodder
Aug 7, 2015 04:27 PM
