adjustment
Old May 24, 2006 | 10:40 PM
70gmc's Avatar
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
adjustment
How do i adjust a 700R4 tranny i know its something with the TV cable but thats all i know. Its very slugish and wait way to long to shift into each gear. Thanks for the help
Old May 25, 2006 | 10:21 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Bowtie Overdrives | TV Made EZ
Old Jun 1, 2006 | 10:14 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
GMC,
As far as the TV adjustment, press the "D-shaped" button on the driver side of the TV cable housing. With the button pressed, push the TV assembly toward the rear of the vehicle. Release the button. Now open the throttle FULLY by hand at the throttle body. The TV assembly will automatically adjust itself to the proper position. While you are opening the throttle, the assembly will be clicking into place. Don't be alarmed by this, it is completely normal. If you are not confident that you performed the procedure correctly, just start over again, it won't cause any harm. Just remember that to obtain the proper adjustment, the throttle MUST be opened FULLY. If your issue is not solved by this procedure, your cable is faulty or the problem lies elsewhere. Good Luck.
Old Jun 22, 2006 | 04:32 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
mine doesnt do any clicking at all when setting it,
stock factory oriignal 84 with 305 and 700r4 and original CC Q jet carb and all
any ideas ?
thanks
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
