700r to tb350
Old May 26, 2006 | 08:51 PM
john w's Avatar
700r to tb350
i changing from a 700r to a 350 and i know i would need to get a tb350 torque arm conversion bracket but my question it that its a 89 firebird and i think it has a eletric speedo and the 350 is cable. is there there a way to make the speedo work or do i have to change the speedo to a cable drive one thanks
Old May 26, 2006 | 09:37 PM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
just change tail shaft on tranny
Old May 27, 2006 | 01:36 AM
CrazyHawaiian's Avatar
Car: too many ...
Have you checked to make sure its an electric speedo? Only the speed density TPI cars (usually 90-92) came with the VSS speedo, an 89 should be MAF TPI and thus a cable speedo. You can verify by either looking at the tailshaft of the current transmission, or cheking behind the guage cluster to see if there is a cable going in.
For info on the TH350 conversion do a search.
Old May 27, 2006 | 11:40 AM
john w's Avatar
i really dont know but the car had a 305 tbi aand we swap that out for a 350 carbed. i dint know you could change tail shaftes
Old May 29, 2006 | 12:51 AM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
i am also thinking of putting a th350 in my 89 gta , when i took my tranny out there was only one cable, the kickdown, and 2 electric connections. i also would like to know if there will be a speedo prob.
Old May 30, 2006 | 05:41 PM
Shagwell's Avatar
Car: projects.......
...'birds got electric speedos by 87.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Ratchet
Dec 7, 2001 09:34 AM
tiffosi
Feb 19, 2001 01:28 AM
Metallica383
Oct 1, 2000 10:24 PM
