T-56 cross memeber
Old May 30, 2006 | 01:46 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
T-56 cross memeber
Ive have swaped a 96 t-56 unit into my 85 trans am. i have a spoon cross member, and adjustable spoon torqe arm. The thing is beefy as hell, but makes racket, clunks on every bump. I have centerd the drive shaft loop on the drive shaft and car. Seams that the conection for the torqe are to cross member is just a poor desighn. Anyone know of a better set up? please help, the car is flawless other then this one problem.
Old May 30, 2006 | 02:21 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
I have the same setup on my car, but without the problems. I would call Steve Spohn directly. He typically is pretty helpful, very knowledgable and stands behind his stuff.
Do you know exactly what is hitting/touching what when you go over bumps?
S-D
Old May 30, 2006 | 02:55 PM
Transmission: t-56
S-D
Well im not positive whats touching, but i belive its the mount where the tourqe arm conects to the mount. they look like there verry close, and i belive when the axle moves up or down there hitting each other. i got the mount and arm used so i did not get any directions. So everything is set up to what made the most sence to me.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
tattmann
Sep 27, 2015 05:20 PM
luvofjah
Sep 26, 2015 08:28 PM
indygene
Sep 26, 2015 11:21 AM
