TQ Converter lock up question
Old Jun 3, 2006 | 12:00 AM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
83 Z-28, originally had Crossfire Injection.
It now has a carbed 305, and the comp and everything was ripped out. And the TQ lockup doesn't work any more, so I spin around 3100rpm on the highway at 65mph. I think my tach reads slightly high though.
My question is, I really want to get this working again. I have been told I would probably have to hook it up to a 12v source, run it through a relay and a toggle switch, and just flip the switch on once I get to my desired speed.
I think I have the wiring for it, but how can I hook this up? Where is the plug-in on the tranni located? Is there a different way I can do it without a toggle switch, just make it do it automatically?
I really need this, bieng that I travel 200 miles every weekend.. and gas prices suck.
Old Jun 3, 2006 | 01:47 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Search bud!
Its brought up at least every few days!
Lockup can be achieved through many methods.
You can use an aftermarket kit that.
You can wire a toggle switch direct
You can wire a toggle that cuts out when brake is applied
You can wire a toggle that only locks up in 4th
You can wire a toggle that locks in 3rd/4th
You can grab a vac switch out of a canadian non computer car
And the list continues...
Old Jun 3, 2006 | 07:21 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
I like the 1 wire 4th gear only lock up kit. Have one on my own car for years. Nice drivability and works fine.
No toggle switch required with the 1 wire kit.
Old Jun 3, 2006 | 07:36 AM
I don't have time to search for that kit at the moment, I have to go to work.. on a Saturday.
Could someone give me a link to all of those kits, please? Would be highly appreciated.
Old Jun 3, 2006 | 08:56 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Unfortunately, I don't have a link to any of them. I usually wire them myself to suit the need. I have seen them on e-bay though. Run a search on 700r4. You may see it there. $20 bucks or so, if I recall correctly.
Old Jun 3, 2006 | 10:53 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
If that is still the '83 700R4 transmission then I would try to have it lock up as often as possible. IOW: not just a 4th gear lockup.
The reason is that the '82 through '84 MY 700R4's have no cooler flow when the TCC is unlocked. Even in the '85 though '92 MY 700R4's reduce the cooler flow by almost half when the TCC is unlocked.
RBob.
Old Jun 3, 2006 | 12:49 PM
Ebay link
What about this here? This doesn't seem to be right though.
Old Jun 3, 2006 | 01:30 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
That part is the actual lock up solenoid. It comes with crimp ends so it can be spliced into your wiring harness during replacement. Not what you need, unless your solenoid is bad. Then you will need this as well.
Old Jun 3, 2006 | 04:14 PM
As far as I know, it should be good. How do I search for the wiring? It only came up with TQ converters, and solenoids.. no wiring harnesses.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
