stuck in park
Old Jun 7, 2006 | 12:18 AM
bd_slim's Avatar
Car: 89 iroc vert-91z-28
Engine: 305 tpi-305 tpi
Transmission: 700r-4-700r-4
Axle/Gears: 3.23 posi-3.73 posi
stuck in park
i'm purchasing an iroc with a 700r4 and a b&m rachet shifter. the owner told me that he thought the linkage was slightly off which wouldn't allow for the car to be set fully into park. now he thinks that it is broken because it won't shift out of park/into gear. any ideas? could it just be a cable or linkage or am i looking at a junk tranny? thanks in advance!
Old Jun 7, 2006 | 12:20 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
cable could be misadjusted/broken/not even hooked up ect...
Could also be the bracket down on the tranny that has broken/come loose/ or cable popped out.
I wouldnt go as far as saying the tranny is pootched, yet...
Old Jun 7, 2006 | 12:25 AM
bd_slim's Avatar
so based on the symptons you think its more likely that its a fairly easy fix
Old Jun 7, 2006 | 12:16 PM
Shagwell's Avatar
Car: projects.......
based on the symtoms, you need to take look under the car while someone is trying to shift it and see if the trans linkage moves....
RedLeader289
May 28, 2019 01:47 PM
tmellott89
Oct 14, 2015 02:06 PM
Luigytico09
Oct 1, 2015 08:46 AM
lewandom
Oct 1, 2015 08:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
