need help with my 700r4
Old Jun 7, 2006 | 03:02 PM
redbirdta's Avatar
Car: 86 transam
Engine: 355
Axle/Gears: 3:73 posi
my ta came with 305 tpi i put a carbureted 355 the main harness is not in the car is getting it to shift by itself easy as pluging in the harness or can i get by just useing the 5 wires that go to the trans. where do i get power from.
Old Jun 7, 2006 | 05:11 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
The wiring not plugged in will cause you to have no lock up. The poor shifting is likely a throttle valve cable geometry or adjustment issue.
Old Jun 7, 2006 | 05:59 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
TV cable and the centifiugal governor controls the 700R4's shift points.
Like stated above the wire harness only controls lockup. without it hooked up the TC will be building extra heat and an aftermarket cooler is recommended. Also you will loose 1/2mpg...
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
