tranny shifting funny
Old Jun 8, 2006 | 11:38 PM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
when im cruising on the highway 70+ and i give it some gas to pas or change lanes or whatever the car shifts from 4th to second(instead of 4-3) and revs somewhere in the neighborhood of 5500-6500 rpm before shifting into 3rd which i dont like. just wondering what could be causing this. i mean i dont want to blow the engine or tranny by redlining or anything.
Old Jun 9, 2006 | 12:04 PM
Engine: 383 HSR EBL
anyone?
Old Jun 9, 2006 | 12:38 PM
Shagwell's Avatar
Car: projects.......
have you verified the rpm other than the factory tach??
Old Jun 9, 2006 | 01:02 PM
Engine: 383 HSR EBL
no just by the tach, the sound of the engine and the absolute lack of power at that rpm.
Old Jun 9, 2006 | 05:21 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Could be the TV cable is misadjusted, or low fluid. I'd start there. Otherwise maybe there is a problem with the governor?
Old Jul 5, 2006 | 08:37 AM
oldman305's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI, 93 LT1 cam, 081 hds, hdrs.
Transmission: Built - 700R4
Axle/Gears: 3.27 gears from '87 TA w/rear disc
Did you ever find out what was causing this problem? I'm having the same trouble and it started all of a sudden.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
