speedo
Old Jun 11, 2006 | 12:27 PM
trans1973's Avatar
Car: 88 Tran Am
Engine: 350 tbi
Axle/Gears: 9 bolt, 327 gears
speedo
whats the best way to get my speedo working, when my speedo is electronic, and the tranny im putting in is set up for a cable. thanks
Old Jun 11, 2006 | 01:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Put a VSS in the transmission instead of the cable housing.
Old Jun 11, 2006 | 01:15 PM
trans1973's Avatar
Car: 88 Tran Am
Engine: 350 tbi
will stock vss from t5 work?
Old Jun 11, 2006 | 01:37 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If the transmission you have now is a T5 and you're using the stock speedo, then yes.
Old Jun 11, 2006 | 02:15 PM
trans1973's Avatar
Car: 88 Tran Am
Engine: 350 tbi
yes, the trans im putting in know is a t5, just an older one with cable drive for speedo. my old trans had the vss, so that should work in the older style trans? my next question is, later on i plan putting a big block and a turbo 400 in, what will i do for the speedo then? thanks alot
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
