Weird T5 question
Old Jun 11, 2006 | 08:21 PM
cheyenne383's Avatar
Car: Huffy 10 speed ;)
Engine: My legs
Transmission: My wrist
Axle/Gears: Little spokey things
Weird T5 question
I am about to re-install the engine and transmission in my 91 RS after some work. When I pulled the T5 out, it was filled with gear lube. The case clearly says in big *** letters fill with Dextron II ATF only. The trans worked fine when it was pulled, should I drain it and refill it with ATF or top it off with gear lube?
Old Jun 12, 2006 | 10:31 AM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
I have run both in my T5. It had gear oil in it when I bought the car, and had replaced it once with the same. The last time I pulled the engine, also changed the gear oil out in the tranny for some ATF. The T5 is considerably more quiet with the ATF (not to mention easier to shift when cold), which it was designed to use.
Old Jun 12, 2006 | 09:40 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
There may be a reason the trans had gear oil in it. How long have you had the car? The gear oil might be quieting the trans due to looser gear tolerances.
Old Jun 12, 2006 | 09:55 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Its true that the heavier gear oil might be hiding noise and comforting worn synchros, but bearings and gears will starve to death with this oil in the case. It will not shift easily when cool. It requires more torque to turn, which equals more wear on the engine and the trans, and poor fuel milage. The funneling system is not adequate enough to throw heavy oil where it needs to go. It will not flow to the 5th gear set in the rear of the trans. Use GMs Synchromesh oil or a mixture of ATF and motor oil of light viscosity. If the trans makes ugly noises...fix it.
KCG
Jun 24, 2020 04:33 AM
Cleotiz
Jan 6, 2018 08:56 PM
87iroctheo
Dec 4, 2016 11:47 AM
NiG
Sep 2, 2015 06:54 AM
CORV3TT3
Aug 23, 2015 11:26 AM
