Slipping between gears...is it my converter or Pro-Built trans?
Old Jun 12, 2006 | 08:40 PM
CamaroX84's Avatar
I recently installed a new Pro-Built 700R4 and an Edge converter. When I shift 2-3 with my foot on the floor at 6000 RPM, it slips about 500-750 RPM before it shifts. Can converters cause this, or could it be my new trans? Thanks.
Old Jun 12, 2006 | 10:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Converter just transfers power from the engine to the transmission. It has nothing to do with how a tranny shifts. Sounds like you have a tranny problem. Start with checking fluid levels.
Old Jun 13, 2006 | 04:49 PM
CamaroX84's Avatar
Fluid is full. With the bad vibratrions I've been getting and now this, I'm starting to think my tranny isn't doin that great now.
Edit: Accidently wrote fluid is not full.
Old Jun 13, 2006 | 06:17 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Before you start knocking Pro Built, go out and check the adjustment on your TV cable. That works with the governor to control shift points and firmness. Cover YOUR bases first before you knock someones work.
Old Jun 13, 2006 | 07:53 PM
EvilCartman's Avatar
Car: '82 Z28
A friend's 700-r4 does the same thing, he hates it. It has done it since day one from being rebuilt before sticking it in his car. Think I had a thread asking about it and Pro-Built said it's the way the clutches/bands apply. One set has to release before the next one can apply so there's a slight delay. Maybe he can shed some light on the subject, my info could be wrong.
Old Jun 13, 2006 | 08:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
EvilCartman, you are correct. While in 2nd the 2/4 band is applied. For the 2-3 shift the 2/4 band is pushed off while the 3/4 clutch pack is applied.
If the 2/4 band is slow to push off, or if the 3/4 clutches engage too quickly, then the trans binds for an instant (in 2 gears at once). If bad enough this can be felt as the vehicle jerks. Followed by a clunk from the rear.
If the 2/4 is fast to push off, or the 3/4 clutches engage too slowly, then the RPMs flair.
RBob.
Old Jun 17, 2006 | 10:37 PM
CamaroX84's Avatar
I'm guessing that's not normal though, right?
Old Jun 19, 2006 | 01:35 AM
Car: '82 Z28
If I remember right, just about every car I've heard with a 700-r4 has that delay in the 2-3 shift. You really need to contact Pro-built and talk it over with him to see if it's a normal thing or not.
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
gta power
Aug 13, 2015 06:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
