fluid change?
Old Jun 13, 2006 | 04:20 PM
25th rs camaro's Avatar
Car: 1992 Camaro Rally Sport
Engine: L03 305 E TBI
Transmission: M5
Axle/Gears: 3.08
fluid change?
its time for a fluid change in my tranny and rear axle what weight should i use. i was thinking that the lucas gear oil 75w 90 looked good i use other lucas products and ive been very pleased with there performance.
Old Jun 13, 2006 | 10:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'd use Red line synthetic gear oil for the diff. Sure it's more pricey, but think how often you change rear end oil, and how much (volume) you're going to need... Then it's not so pricey.
I think the later T5's were spec'ed to take ATF. I know, sounds weird, but it's what I heard. Check if your year is meant to take that or not (or see what's in it first..)
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
