Need some advice!!!
Old Jun 19, 2006 | 03:21 PM
BobbyRod's Avatar
Car: CAMARO RS 25th Anniversary Z03
Engine: L03 V8 5.0
Transmission: THM 700 R4
Axle/Gears: 2.73 OPEN
Need some advice!!!
OK, The thing is that I took a 100 miles trip on friday and came back on sunday (interstate driving), everything was OK till I got stuck in city traffic, and then without apparent reason the transmission wouldn't shift from 1st to 2nd even making it manually untill it reached 4500 RPM
My transmission is a THM 700 R4 (MD8) year 92, today I had it checked with a mechanic and he said there was no problem at all, he took a test drive and the transmission worked fine.
Before that i've had some overheating problem, but I've already fixed it. could this be related???
I just want some advise on what should I do??? rebuild it or keep going on this one, maybe it's a warning for something
for the help you could give me, i'd really appreciate that!!
B-Rod.
Old Jun 19, 2006 | 03:38 PM
UgotSmoked's Avatar
Car: 88 IROC-Z
Engine: fully built 383 stroker
Transmission: Tremec TKO-600
B-Rod.
wow that is interesting. from what you have said though it sounds like it may be an overheating problem with the transmission...do you have a transmission cooler by any chance?
Old Jun 19, 2006 | 04:46 PM
BobbyRod's Avatar
Engine: L03 V8 5.0
No, I don't but i'm considering installing one soon, I've been reading and concluded that it woulb be for good.
What do you think thatcould be happening?
Old Jun 19, 2006 | 05:11 PM
irocalot's Avatar
Pretty much anything bad in a transmission shows up in the fluid - I'd be pulling the pan and looking for debris - sniffing the fluid to see if it's burnt...
I'm not sure if a bad/sticky tv cable would cause no shift - but I would be looking it over carefully - especially the ends...( perhaps the inner core is fraying?)...
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
