sound like tranny slipping?
Old Jun 19, 2006 | 06:14 PM
CC89Formula's Avatar
Car: 89 Formula
Engine: 5.7 TPI
ive got an 89 formula with L98 and a 700R4, probably 8 or 9 months ago i installed a holley stealth ram, before if i put it in first and accelerated to 30mph i was at 3000rpm. after i put the stealth ram on, 30mph was 4000rpm. does this sound like the tranny is slipping or could it be something else? i have already adjusted the TV cable (i think is what its called) but still the same thing. thanks in advace
Old Jun 19, 2006 | 07:19 PM
Z28cross-fire's Avatar
Car: '94 Z28
Engine: LT1 350
Transmission: 4L60E/A4
Could be other problems relating to the install of the HSR. The manifold might be leaking when it gets vacuum causing the slightly higher RPM. If it happened really quick after the install, like within a week, I would be inspecting the HSR first.
Old Jun 20, 2006 | 12:54 AM
Car: 89 Formula
Engine: 5.7 TPI
so maybe i just have a vaccum leak...hmm never thought of that...
Old Jun 20, 2006 | 01:05 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
TV cable adjusted properly and have the proper geometry?
Old Jun 20, 2006 | 03:11 PM
Car: 89 Formula
Engine: 5.7 TPI
geometry is probably a different story, as the stealth ram sits higher and we had to bend the bracket to make it fit
db057
Jan 10, 2020 08:55 PM
gta892000
Aug 11, 2019 11:16 AM
camaronils
Sep 20, 2015 02:57 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
