electronic speedo
Old Jun 20, 2006 | 01:36 AM
87pontiac's Avatar
Car: 87 Firebird
Engine: 2.8l-(350 on the way)
Transmission: auto-(for the wife)
electronic speedo
If I change the wheel size from 15" to 14", will the electronic speedometer still be off?
Old Jun 20, 2006 | 09:30 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
If you can keep your basic tire diameter the same or really close then you shouldn't notice too much of a difference.
Old Jun 21, 2006 | 04:28 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
still be off? as in you are trying to fix the speedo or u are wanting to go to a 14 and want to know if it will mess it up
Old Jun 21, 2006 | 10:56 PM
87pontiac's Avatar
Car: 87 Firebird
No ,the speedo is OK, I was just wondering about the accuracy if I went from 15" to 14".Right now I'm runnuing P205/75R-15 and I was looking at the car with 14" and 215/65R-14.The car looked good a little lower to the ground.I'm going to keep the 15"s and go for a somewhat wider and shorter tire after the body work is done.
I was just wondering, since I have the Electronic Speedo, it wouldn't be out if I change the wheel size.
Thanks for the response !!!!
Old Jun 22, 2006 | 12:22 PM
Car: 87 trans am
oh yeah u should have no problem, if may look like its off, you might second guess yourself but it shouldnt
Old Jun 22, 2006 | 01:11 PM
87pontiac's Avatar
Car: 87 Firebird
Sounds good! After the body work is done , the never ending search for Diamond Spoke Aluminum wheel continues!!!!!!!!!!!!!!
Thanks Again for the insight!!
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
MrPackstin
Oct 25, 2017 08:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
anesthes
Sep 30, 2015 07:48 AM
