9 bolt question
Old Jun 21, 2006 | 10:41 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
9 bolt question
put a 9 bolt in my IROC a month or so back. I was planning on putting my 10 bolt back in so I'd bought gear lube and pos additive. When I changed lanes and prepped the 9 bolt I just put the pos additive and gear lube in it and installed it. Not having any experience with 9 bolts I just got to wondering if I should have used the pos additive. Any input is welcome.
Old Jun 22, 2006 | 03:25 AM
ede's Avatar
ede
you'd want the posi additive in any clutch type posi unit, any other type of posi wouldn't need it
Old Jun 22, 2006 | 08:52 AM
Z's r Best's Avatar
Thanks. After looking inside the housing I wasn't really sure it had clutches/springs. It doesn't look anything like the 10 bolt pos units. I needed a disc brake rear end and it was sitting out in the building so I put it in the car. Thanks again.
Old Jun 22, 2006 | 09:07 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
You will NOT want to use the fluid. The 9 Bolts are Cone type and require friction to hold unlike the 10 bolt units.
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
