transmissin mount shim question?
Old Jun 21, 2006 | 11:50 PM
Luther6704's Avatar
Car: 1986 Iroc
Engine: 305 TPI w/30,000 original miles
Transmission: 700r4 Transgo Shift Kit
from what i understand theres a snafu with the poly mounts by energy suspensions concerning different cross members, and whether or not to use the shim. I have an 86 iroc with a 7r4. to shim, or not to shim?
Old Jun 21, 2006 | 11:53 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I didnt on both cars
Old Jun 22, 2006 | 12:20 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Use the shim if you need to correct the pinion angle.
Old Jun 22, 2006 | 04:16 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
There have been instances where the shim has caused mysterious vibrations. Typically I leave them out, unless the car has been lowered, and then sometimes you need the shim to correct the tailshaft angle to get the u-joint operating angles into line, as mentioned.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
