How much will i hate 2.73s'?
Old Jun 24, 2006 | 07:48 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
I just got a 4th gen rear with disc and posi,Replacing my drum and non posi rear.The bad news is the gears are 2.73 in the new axle and 3.42 in my old one.I'm not comfortable swapping the gears,so i'll have to run the 2.73 for awhile.I'm not sure how much i'll loose in performance,but the 3.42s' weren't really doing me any good because all i do is spin one wheel.From what i read,my gas mileage should go up as well as my top speed,but i'm not sure about around town driving,will the car "lug" and will the shift points change at all?Will it be a dog off the line?Anybody with 2.73s' care to let me know what i'm in for.My 350 works pretty well,so i'm hoping i can trade alittle gear for some traction without it hurting to much.
Old Jun 24, 2006 | 09:22 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Actually you will lose gas mileage probably. you will have to use dang near WOT to get the car moving then you will be at a really low RPM while cruising wich will make the engine lag really bad. It will still run fine with them but you wont have any power + it will use more gas cause it has to struggle to move the car from every stop.
Old Jun 24, 2006 | 02:37 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I don't think you will like the gears at all. You will cruise at low rpm's but that will be the only benefit. You are going to hate driving around until you get better gears.
Old Jun 24, 2006 | 02:57 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
2.73 is crappy unless you hvae a nice deep first gear like in a 700r4
otherwise its pretty doggy
try to avoid it if at all posible
3.42 and 3.73 were common in alot of the 84 and later stuff
Old Jun 24, 2006 | 03:14 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Only way you will hate the 2:73 geared rear is if you listen to the comments. These are made by people who think a low gear is the best and most will have the same as you. As long as the horses are up front the rear is going to move with them.
Old Jun 24, 2006 | 03:17 PM
LT1FUN's Avatar
My '93 came with 2.73's and I got gas milage better than any Honda I knew of
They didn't stop me at all from ripping the tires off the car either, and the top-end was amazing (both in acceleration and top speed)
Since then, I've run 3.42's, 3.73's and 4.10's. (Currently back to 3.73's)
The 3.42's were the best "all around" gears for sure. Good acceleration from a stand still, and decent fuel consumption in city/freeway driving.
The 3.73's and 4.10's will get you off the line better (so long as you can hook up) but you're milage will suck on the freeway, youre top speed will be reduced quite a bit, and the car just won't pull as hard on the freeway either. I was actually surprised at how much harder the 2.73's pulled at freeway speeds over the lower gear ratio's
The 2.73's might not be the best for 1/4 mile acceleration, but you'll be really happy with how quite the car is on the freeway (your motor will be spinning at much lower RPM's) and you'll get way better fuel economy.
I suggest you just give 'em a try. It's only temporary right? Why not. You're car put's out more than enough torque to get you off the line and those 2.73's will keep you in the powerband longer. Wouldn't surprise me if you were even a bit faster then with the 3.42's since you had such a problem with traction earlier....
Oh, and you'll be able to do killer burnouts with 2.73's as well
Let us know how you like them should you choose to run them for a while..
Old Jun 24, 2006 | 10:14 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
It wont be that bad. It wont be nearly as fast as it was before, but it will fly on the freeway.
I have swapped a 2.56 gear out of an 86 Vette and put in a Moser straight axle 12 bolt with 4.11s, boy that made a difference.
Old Jun 25, 2006 | 01:17 AM
xplane's Avatar
Engine: 2.8 MFI
I agree with them for a V8. some how i got the idea in my head that this was a V6 car hmm... crazy, wow i feel kinda dumb now
Old Jun 25, 2006 | 02:26 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Don't feel dumb Explane,My car was originally a 2.8 like yours,maybe you picked that up from my sig.Anyway,i kind of like what i'm hearing.I'm gonna hopefully get the rear ready to go in the car after my family vacation.I want to rebuild the PBR calipers and replace the flex hoses,rotors and pads before i install it,but the gears are gonna stay for now.Thanks for the encouraging words.
Old Jun 26, 2006 | 06:21 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I had them in the vert up untill a couple of months ago. You will be turning a little under 2000 rpm's @ 80 mph with a 700r4 and 25.7 inch tire. I got about 25mpg doing 80 in mine. I then swapped in a 3.42 and get about 24mpg doing 80, I think when I swap in the .63 overdriven t-5 I can get 26-27.
sammy52401
Nov 11, 2015 07:20 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
64Chief
Sep 12, 2015 08:05 AM
