identifying torque converter
Old Jun 26, 2006 | 07:32 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Anyone know how to Identify a lockup from a non?
how do you determine stall speed?
thx
jeff
Old Jun 26, 2006 | 08:54 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I don't know of any way to determine that just by looking. Stall speed is determined by the pitch and number of turbines inside the converter and the lockup function is provided by a friction material inside the converter as well. The best analogy of a torque converter that I have heard is; think of two fans facing each other. When you turn one fan on, the other starts to spin too. The faster you spin one fan, the faster the other starts spinning. Now add more blades and provide more pitch and you will make more air flow. This is exactly how the converter works, except with fluid instead of air.
Old Jun 26, 2006 | 10:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The true stall speed of a converter will vary from engine to engine. The only way to find the true stall speed is with a transbrake.
My converter behind my old engine stalled at 5700 rpm. Behind my new engine it stalls at 6100 because the new engine makes a lot more torque. Same converter, different stall speeds.
Just by looking at a converter, there is very little you can to to identify it. If you're lucky and it's an aftermarket converter, there may be a manufacturer name and part number on it which will help. If not then it's just a guess.
88rscamar0
Sep 23, 2015 09:08 PM
Linson
Sep 21, 2015 01:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
angel2794
Sep 8, 2015 06:22 PM
