uh oh... CLUNK!
Old Jun 27, 2006 | 08:24 PM
UDAMON's Avatar
Car: Mazda Protege5
uh oh... CLUNK!
ok so if im stoped and hit the gas hard it makes a loud clunk that you can feel before taking off. its almost like the driveshaft gets caught up or something.
i can feel/hear it more towards the tranny end but im not sure if its comming from there or the rearend.
any ideas??
Old Jun 27, 2006 | 08:39 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Sounds like a broke tranny mount.
Old Jun 27, 2006 | 08:48 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Agreed. Check your tranny mount and universal joints. I would bet the farm that it is time for a new mount. I would recomend an aftermarket poly unit.
Old Jun 27, 2006 | 09:27 PM
UDAMON's Avatar
Car: Mazda Protege5
thanks guys! ill have to get down there and check tomorrow.
Old Jun 27, 2006 | 09:29 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
A broken mount doesn't always stand out with a tell tale failure. Look for small cracks in the rubber as well as prying on it a bit with a pry bar. if you can move the tranny then chances are it is broken. GM tranny mounts are notoriously weak and prone to failure. I had to replace the mount on my 3rd gen as well as my 4th gen.
Old Jun 27, 2006 | 10:19 PM
87IROCZ350TPI's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: BW 7.75" 3.27
I've had to change my thirdgen mount abut five times in the past eight years. Last time, I switched to the poly.
Old Jun 27, 2006 | 10:44 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
its most def the tranny mount first weekend i took my car out it snapped doing a burnout and the tranny whacked the tunnel and you could feel it hit hard. all better now with the help of a whole 10 minutes
F-body driver
Mar 6, 2023 11:44 AM
luvofjah
Sep 26, 2015 08:28 PM
ynk1121
Sep 12, 2015 12:27 AM
Ragtop Man
Sep 12, 2015 12:23 AM
BlackBoulder
Aug 11, 2015 11:15 PM
