Need help with a TH350 Transmission; guidance
Old Jul 5, 2006 | 10:45 PM
onfir3's Avatar
Car: 85' TransAm
Engine: Chevy 350
Hey, It's me again, refer to last post if you want to hear my situation, I'll spare the length. I messed up, my tranny is a turbo 350 not a 700r4, but the info from the last post i got was basically this, from floor guy:
Deluxe rebuild kit. This will usually include the bushings needed, teflons, clutches, steels, band, filter etc. Approx $125
vette servo
470 or 500 boost valve
87 and later 28 element sprag assembly
.283 boost valve
10 vane pump guts and new vanes
updated accumulator pistons
new lo-roller clutch
beast reaction shell
That was for a 700r4, what would be different for a th350. I can kinda figure it out, but there are some spots I'm sketchy on, note this is my first time acctually rebuilding and Auto. Looking at getting most of the parts from this site, need tranny to hold 400hp at min, but its a DD so I don't beat on it.Chevy and GM 350 and 400 High Performance Transmissions
Search #k13, then also the small elevated pressure valve.
Are these prices decent or should I keep searching. Also, they have a sprag setup on there, but its wicked expensive, and then there is a book as well. Could use some help here, need to get a parts list together sometime soon. Thanks all. Cheers.
Old Jul 7, 2006 | 10:07 PM
onfir3's Avatar
Car: 85' TransAm
Engine: Chevy 350
No more help yet? meneh.
Old Jul 8, 2006 | 06:23 PM
bowtienick's Avatar
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
from what i know, the list of parts for the 700r4 is only for that trans. a th350 heavy duty rebuild kit shold be all you need . you may need some help swapping out the tranny in the car. this is a good thread.
https://www.thirdgen.org/forums/tran...ight=tailshaft
Old Jul 13, 2006 | 10:37 AM
don71's Avatar
Car: 1992 rs
Engine: stock 305 tbi
Transmission: t5
Axle/Gears: 3.42 10 bolt
ive had that kind of power in front of a stock th350 witha good shift kit and 3500 stahl id just put in a good rebuild kit and a shift kit put it back in and let it eat
wigmobile
Feb 26, 2025 02:56 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
romcjr
Sep 17, 2015 05:18 PM
89newfun
Sep 16, 2015 09:28 AM
