Rear End
Old Jul 8, 2006 | 10:49 AM
jjohnston's Avatar
Car: 91 Camaro RS
Rear End
What kind of rear end is in the 91 Camaro RS TBI. The one with the 305 and the 700R4 Tranny. Is it the 9 bolt or what? I want to find a POSI CARRIER for it. Anyone know where I can find one of those for my car? I've searched, but found 85 Irocks, etc. Not quite sure if there the same or not.
Old Jul 8, 2006 | 11:57 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
it's a 10 bolt i'm pretty sure they only ofered 9 bolts until 89. also the 91-92's i believe have a 28 spline axle instead of 26 like the earlier ones. So you have to get a carrier from a 91-92. Maybe even a 4th gen carrier will work i don't recall.
Old Jul 19, 2006 | 07:29 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
the ratio's are either a 2.73 or 3.23's
Old Jul 19, 2006 | 10:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
count the number of bolts on it.
9 bolts were offered *after* '89. So it could be either.
I'd put my money on it being a 10 bolt though.
But yea, if you've got a 10 bolt, then it's a 28 spline unit. The ones from pre '89 have 26 splines, so the carrier won't work unless you take the axles too.
You can get axles from superior gear (off summit if you want), for ~$230 26 or 28 spline. A posi unit is ~$400 new.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
