ever feel cursed? I do, rear end question.
Old Jul 9, 2006 | 04:30 PM
net_coma's Avatar
I just completed installing a 10 bolt in place of the worn out 9 bolt. The gears looked good and recently new as stated prior to purchase. I just took the car for the test drive and, imagine it, there is a whine in the rear end. Nothing under power, may have heard something under slow acceleration but in coast the wine is at first not there then builds slowly for about 5-10 seconds and then is clearly audible.
Anyone have insight as to what/bearing it is? I do know there is a leak on the pinion seal, discovered while on jack stands doing the associated brake upgrade.
Old Jul 9, 2006 | 04:38 PM
ede's Avatar
ede
since it has new gears i have 2 guesses, either the gears are set up wrong or the bearings were installed dry and one or more failed. the leaking seal would tend to confirm it was installed dry and the bearings as well.
Old Jul 9, 2006 | 04:57 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Its gotta be gears, a typical worn out gear set will howl on decel.
But like stated above, if their new and werent lashed properly they can/will howl.
Old Jul 9, 2006 | 05:01 PM
net_coma's Avatar
Gears look good with no visible signs of wear. I will take it someplace and have it diagnosed and repaired...I already used all of my rearend knowledge and skills to make the swap.
Old Jul 13, 2006 | 10:31 AM
don71's Avatar
Car: 1992 rs
Engine: stock 305 tbi
Transmission: t5
Axle/Gears: 3.42 10 bolt
ive put three different sets of gears and on with a posi ive replaced all bearings including axle bearing and seals and set everything to spec but my rearend still does this but mine isnt that loud
Old Jul 13, 2006 | 05:11 PM
net_coma's Avatar
It got even better after driving at speed. The Camaro vibration was not there until I replaced the rearend, now it is there at 65ish just as it was in my last one. After I get the pinion seal replaced and the gear set up checked it will be time to replace the axles.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
novaderrik
Aug 10, 2015 12:44 PM
