can gm's alison transmission fit in a thirdgen
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
im just curious if it can. ive seen the gear ratios for this tranny and they are bitchin.
Engine: 383 HSR EBL
Allison 1000
The Allison 1000 is rated to handle up to 520 ft·lbf (705 N·m) of torque.
Gear ratios:
1 2 3 4 5 R 3.10 1.81 1.41 1.00 0.71 4.49 Applications:[edit]
Allison 2000
Gear ratios:
1 2 3 4 5 R 3.51 1.90 1.44 1.00 0.74 5.09 Applications:
Gear ratios:
Allison 2000
Gear ratios:
- B-7 bus
- C-Series truck
- F-Series truck
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Those are truck gears. Very low first gear to get 5000+ pounds moving. 1:1 final drive and one OD gear.
A 4L80E would be a better choice and it's not exactly a lightweight tranny either but it would fit better. A beefed up 200-4R could do the trick also.
1992 Trans Am
Aug 8, 2015 08:16 PM
