ford 9 inch brackets
Old Jul 10, 2006 | 06:17 PM
k's89rs's Avatar
Car: 89 rs, bmw 325 is
Engine: 360 (.060) 2.5L inline six
Transmission: 700r4, 5-speed
Axle/Gears: 9 bolt 3.08 3.? limited slip
where is a good place to get the suspension brackets for a ford 9 inch conversion? how much do they normally run?
kent
Old Jul 10, 2006 | 07:05 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Cut them off a donor 10 bolt. Measure at least 3 times and weld onto 9" housing once.
You still need to find some way to attach the torque arm if you plan on using a factory type suspension. Moving over the spring, shock, panhard bar, LCA mounts is the easy part.
Old Jul 10, 2006 | 11:20 PM
k's89rs's Avatar
any one make a 4 link kit sans the toruqe arm? i wanna try to get rid of it.
Old Jul 10, 2006 | 11:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Not without doing a complete back half.
The Official S & W Race Cars Web Site
Old Jul 11, 2006 | 09:53 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
out of curiosity, what makes the TA mount harder then the other mounts?
Old Jul 11, 2006 | 02:14 PM
Shagwell's Avatar
Car: projects.......
it mounts to the housing instead of the axle tubes. Axle tubes are mild steel, housings are cast. Cast is tricky to weld properly.
- You can't 4-link without back-halfing the car and loosing you're rear seat. - Why would you want to loose the tq arm when it works so well when done properly? The factory "4-link" cars(rustangs, etc..) take 3x(from my experiences) the work to get to the 60fts a tq arm car can and they're less consistent. Aftermarket 4-link set-ups are great, bt now you're talking a full-on race suspension and no rear seat, plus major modifications.
Old Jul 11, 2006 | 02:27 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
on a 10bolt, 9bolt and aftermarket 12bolt, they cast the torque arm mount into the housing.
on a 9", you cant put it on the housing, since the 3rd member drops out... well i suppose you COULD but most wouldnt want to.
because of that, you need to make a bracket thats close to the 9" centersection, removable, and very strong.
Old Jul 11, 2006 | 02:32 PM
Shagwell's Avatar
Old Aug 27, 2011 | 11:30 AM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
Re: ford 9 inch brackets
Back from the dead. Does anybody make a kit that you can buy to weld on to a donor rear end housing? I mean, QP has to be getting them or making them somewhere.
Old Aug 28, 2011 | 10:45 AM
Guest
Guest
Posts: n/a
http://www.currieenterprises.com/ces...6.aspx?id=1595
Old Aug 28, 2011 | 11:29 AM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Thanks! That's exactly what I was looking for. The whole kit is $350 looks like
http://www.currieenterprises.com/ces...E.aspx?id=1769
For $650 you can have the complete housing with ends welded on from Moser. Yeah...I can see why a lot of people just order it instead of doing it themselves.
Old Aug 30, 2011 | 06:13 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
autoweldchassis.com has the best ford 9 set-up I have ever seen. It's what I put under my IROC. There torque arm and crossmember set-up is better than anything I have seen.
Old Aug 30, 2011 | 06:23 PM
Guest
Guest
Posts: n/a
The best? Maybe. It's an American obsession. But a few of us can be perfectly happy with "good enough". In fact, that's the new name of my '84.
Old Aug 30, 2011 | 06:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
midwest chassis has probably the best one i ahve seen, with the most options.
http://www.midwestchassis.com/products.html
Old Aug 31, 2011 | 05:05 PM
abray1's Avatar
The top picture on Midwestchassis.coms site is almost identicle to the set-up I bought from autoweld. To be honest I had never heard of midwest but there stuff is top shelf. I like the torque arm mounts that mount to the very top and bottom of the rear end housing. They supply a custom crossmember also that is very strong and adjustable like autoweld. I wonder just how many of these shops are out there. If any of you guys are going to build a ford 9 do a search for used nascar parts and you will find some awesome deals on top parts used by Hendrick, Childress and other race teams. I ended up with a detroit locker, 375 polished gears and a 1350 yoke with the pulley on it for the rear end cooler from Jeff Gordons car. That was in 2002 I think when there was just two teams at Hendrick. I have found stuff from Hendrick, rousch, Childress, Earnhardt and Gibbs at great prices.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
armybyrd
Sep 15, 2015 06:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
