what trannys bolt up?
Car: 88 camaro
Engine: 355
Transmission: rebuilt 700-R4
what trannys will bolt up to a 89 block, ive heard pple doing t-56 conversions does it bolt up to an older block. what trannys will???
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
howdy there
this is a very generic question, we could be here all year listing every thing that can and will up to a sbc engine,,,
most all GM transmission models were made in both 60 and 90 degree versions, separately- not combined-
there were none that fit both degrees,
however there were some that would fit not only chevy pattern but also had four extra holes so that they would fit caddy pontiac buick and oldsmobile 90 engines too, *of the same degrees*
any tranny that is 90 degree bellhousing and the correct spline for your clutch disc will bolt up
v8 are 90 degree and 4.3L and straight six engines too
chevy pattern
Transmission
TLC Parts
http://members.tripod.com/~grannys/r...ctioninfo.html
Engine Swaps
scroll down
"Chevy small block 90 degree engines include 200, 229, 4.3 in V6. V8's that share many parts with the V6 engines are 262, 265, 267, 302, 305, 307, 327, 350, and 400. Stroker and destroked motors made using these base engines are 301, 383, 388, and on up to about 427 cid.
Chevy big block 90 degree engines include 366 tall deck, 396 and 402 short deck, 427 short and tall deck versions, and 454 short and tall deck versions. 502's are available and will swap with the other big block engines. Bigblock and small block engines share the same bellhousing pattern which means, for example, that if a 229 V6 came out, A 454 "Rat" Chevy engine will "bolt up" to the transmission. None of these 90 degree engines fit in a front wheel drive car."
you have much to learn
and once you learn then you will always know,
it is easy to visually psot a 60 degree bellhousing from a 90 degree, the 60 degree sides are way steeper than 90 degree sides, and the 60 degree tops are wider across than the 90 degree, or are totally flat anyways, unlike 90 degree(talking about just the casting shape, not the bolt hole locations- the top two that is)
good luck
chevy pattern
Transmission
TLC Parts
Engine Swaps
scroll down
good luck
manual trans bolting up to a motor? Auto yes, 60 and 90 degree is all that really counts for generic "bolt up", but for a manual trans, it all depends on what bellhousing you use. Hell, I've run a chrysler 18-spline "crash box" in a 427 bbc Camaro.
- some trans are direct bolt-up for our factory bell, many aren't. Many can be made to bolt on via an adapter, some no adapter is available for "bolt up". Most can be made to fit, but that all depends on either your knowledge and abilities, or you check book balance.
Car: 88 camaro
Engine: 355
i dont really wanna learn the mechanics of a tranny all i wanna know is if basically a newer camaro (chevy) like a 4L60e or T56 will bolt up and work on a 89 block?? anyone? thanks for the input.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Its been done here a million times.
The 4l60e is in short a 700R4 controlled by computer. this swap requires you to hack up a newer computer to run the tranny or get a stand-alone computer for it.
T56 has to be one of the most common manny swaps here...
2.8,engine,what transmission will fit 4x4
Im wanting to know specific transmission that will bolt up to my 4x4 2.8,i solely use it for plowing snow and with not much money in pocket,need the diffrent kinds of transmissions that will bolt up to my 2.8 v6,can i 2 wheel drive transmission bolt up,i heard you can take off the rear cap to the tranny and would bolt up to the transfer case is this true,,help !
Car: 89 RS, 93 Z28
Engine: Vortec 350 TBI, Lt1 6 Speed
Re: what trannys bolt up?
the straight drive transmission doesn't bolt to the motor, it bolts to a bell housing
UltRoadWarrior9
Sep 2, 2015 08:24 PM
